A.Frank Vigil, senior
building science specialist at Advanced Energy in
Raleigh, N.C., responds: Reports are
increasing of problems with black stain deposition
on interior surfaces. Since particulate is
attracted to cooler surfaces, it is not uncommon to
see black staining following the framing members
behind sheetrock. The source of the particulate
varies. We have documented sources ranging from
furnaces and water heaters to fireplaces, candles,
outdoor cooking grills, and even automobile
tires.
Although you say the fireplace has been tested
for leakage, not all technicians test for all
possible problems. Was the fireplace tested under
pressure or simply examined? Is the fireplace a
"sealed" unit? Some units appear to be sealed, but
when tested under negative pressure can leak
significantly. Is there a standing pilot light? If
so, how large is it? Does it impinge on any of the
logs? Has the gas pressure been tested? Was the
orifice examined to make sure it is the correct one
for the fuel being burned? These items should all
be checked, since we have found that any one of
them might be the source of particulate matter.
We also know that some candles — as
well as certain candle-burning practices —
can be the source of black stain deposition.
Unfortunately, it can be difficult to predict
beforehand which candles will lead to problems.
Many types of jar candles, imported candles, and
highly fragranced candles can burn dirtier than
other types. Candles that are poorly designed or
have improper wicks can also be problematic.
Improper burning practices include failing to keep
the wick trimmed, burning a candle anywhere near a
draft (for example, near a heating register or
ceiling fan), and burning a candle for too many
hours. Any of these practices can lead to
staining.
If you suspect that a candle is the cause of the
staining, tell the homeowner to stop burning the
candle for a few months. If the stains return to
the ceiling after repainting, you know the source
is from something else. Covering the stains
requires a good quality sealer, such as Kilz, prior
to painting. Otherwise, the stain will bleed back
through the paint.
Because particulate is attracted to cooler
surfaces, there is a strong likelihood that the
ceiling insulation is poorly installed —
perhaps because the insulation is compressed at the
edges or because there are voids or gaps along the
edges of the insulation. The owner of the house may
wish to improve the ceiling insulation.
For more information, see my article "Black
Stains in Houses: Dirt, Dust or Ghosts?" in the
Jan./Feb. 1998 issue of Home Energy magazine
(510/524-5405).
