- Q.I am trying to plan the best
way to ventilate a hipped roof above an attic. Since
the ridge is very short, ridge venting is not an
option. I was planning to install powered exhaust
ventilation. How should I size the fan?
A.Bill Rose, architect and
building researcher at the University of Illinois
in Urbana-Champaign, responds: Although many
building codes require attic ventilation, there are
more important factors than ventilation when it
comes to designing an attic and roof system that
works well. First, be sure the following points
have been covered:
- seal any cracks where air can move into the
attic or cathedral cavities from below,
especially at mechanical chases and the access
hatch;
- insulate well above the living space;
- keep mechanical equipment and ductwork out
of unconditioned spaces;
- divert rainwater well away from the
foundation in order to keep the foundation from
contributing excessive humidity to the house;
and
- flash the roof correctly.
And ventilation? For hip-roof homes,
I’ve had occasion to recommend soffit plus
mushroom vents, soffit only, and no vents at all,
depending mostly on the predisposition of the
client. Clients concerned about strictness of code
enforcement and shingle warranties should have
ventilation by the book, and should have simple
designs to match the simplicity of the venting
requirement. Clients with complex conditions
— dormers, cathedral sections, flat-roof
sections, shed sections — as well as
clients in fire-prone regions, should investigate
construction without vents. I suspect that
soffit-only venting may give some relief of
occasional water without the strong suction of high
vents or the possibility of rain or snow entry, and
I’d encourage more research and
experimentation with this approach.
I’ve never had occasion to recommend
powered venting. It’s noisy and expensive
to operate, and I haven’t seen evidence of
a payoff. If you still want to know how to size an
attic exhaust fan, my answer is: as small as
possible.
