First Look: Power Box; Safety Kit; and Gates
Blackline Vinyl Fence Products. The Slimline 3-by-3-inch posts and 2-by-2½-inch rails are as strong as the larger originals, yet the smaller size allows a more refined look. Made of PVC homopolymer compound, the posts and rails are designed to replicate the look of ornamental wrought iron. They do not require painting or sealing and will not warp, crack, break, or splinter. (866) 333-1050. www.blacklinefence.com.
Bosch. The Power Box rocks in more ways than one. It entertains: Listen to the AM/FM digital radio, play CDs, or plug in your own MP3 player. And it also works: It has a four-way GFCI power outlet, battery charger, and a 12-volt outlet perfect for charging cell phones. This reduces the need for separate extension cords — the Power Box only uses one outlet. Housed in an aluminum roll cage, it’s safe from jobsite hazards. (877) 267-2499. www.boschtools.com.
Dynapaq. “Safety first” should be every remodeler’s motto, and it’s easier than ever to put those words into action with the Safetypaq high-performance safety kit. “Comfort-max” earplugs, two pairs of form-fitting safety glasses, and a pair of high-dexterity work gloves with leather palm surfaces and a neoprene cuff all fit in a plastic case that has magnets on the back for easy storage in the truck or on the jobsite. (800) 559-0491. www.dynapaq.com.
L.B. Plastics. Ready To Assemble (RTA) Gate Systems are designed to be easy to install and to custom fit. The gates are fully adjustable during installation and have rigid reinforced aluminum corners and heavy duty hinge and latch hardware. Each kit contains all the components and mounting hardware necessary to complete assembly. The gates are constructed of low-maintenance PVC and are available in privacy, semi-privacy, railing picket, and ranch versions. (800) 752-7739. www.lbplastics.com.
