In Focus: Heat pumps; programmable thermostats; and more
Broan-NuTone. Meant to be unobtrusive, the U102 Slim-Line Under-Cabinet range hood leaves only 1½ inches visible when it’s slid away under the cabinet. A full 18½ inches deep when in use, the hood is available in 30-, 36-, and 42-inch widths. It features a 500 CFM internal blower and dual halogen lighting with two settings. 800.558.1711. www.broan-nutone.com.
York. The latest in the Affinity series, the 3S and 8T model heat pumps are Energy Star qualified. Scroll compressor technology offers increased efficiency, says the maker, and a full end, full service access panel with a handle makes installation and servicing easier. In addition to the standard Champagne, the pumps are also available in colors such as Terra Cotta (shown) and Chocolate. 405.364.4040. www.yorkupg.com. Panasonic. The WhisperFit-Lite low-profile ventilation fan offers a slim design that promises to be easier to fit into small ceiling cavities. The housing is 5½ inches deep. Two 13-watt compact fluorescent lamps provide illumination and a nightlight option. 866.292.7292. www.panasonic.com/building. Honeywell. The VisionPro touch-screen programmable thermostat promises to be user-friendly and easy to install. Boasting a 10-inch-square touch-screen display, the thermostat can be programmed up to seven days in advance. A “change/check reminder” lets homeowners know when filters, batteries, and other items need to be replaced or checked. It can also be taken down from the wall to be programmed. 800.328.5111. www.honeywell.com/yourhome. Hydro-Therm. The KN-10 commercial gas-fired boiler employs Tru-Flow technology — a “self-adaptive” design that adjusts air and fuel under various conditions to maximize performance and boiler safety, according to the company. Less than 27 inches wide, it can be easily fit into a number of applications. 413.564.5515. www.hydrotherm.com. For more product information, visit ebuild.com, Hanley Wood’s interactive product catalog.
