Homeowners often ask, “Which entry door should I choose: steel or fiberglass?” The short answer is – it depends. The technology for both has come a long way, and either choice can deliver long-term performance. The choice depends on a homeowner’s personal taste and preferences.
Fiberglass Entry Doors
- Fiberglass doors most closely mimic the defined grain of traditional wood doors and are available in smooth finishes as well, in a variety of stain, glaze and paint colors.
- Fiberglass entry doors do not shrink, warp, split, crack or delaminate. They’re ideal for harsh and humid climates, and because they last so long, many come with strong warranties
- Fiberglass entry doors offer low maintenance, resist denting and can be cleaned with mild soap and water
- Fiberglass entry door systems are engineered to be highly energy efficient. The polyurethane core, heat-resistant window trim, weather stripping and glazing systems work together to keep out the cold in the winter and keep out the summer heat.
- The solid construction of fiberglass entry doors provides significant security.
- Fiberglass entry doors are often less expensive than high-end wood doors and offer longer durability.
Steel Entry Doors
- Steel entry doors are available in smooth or woodgrain textures, in multiple stains and paint finishes, and come in a variety of door styles, including some with glass.
- Steel entry doors, particularly those made of 20-gauge steel, won’t crack or warp and are the strongest, most durable doors available.
- Steel doors will offer low maintenance depending on the galvanization (rust prevention) and thickness of the steel. Some offer paint and stain warranties as well.
- Steel entry doors offer significant energy efficiency.
- Steel entry doors offer the best solution for homeowners who are concerned with home security.
- Steel entry doors are affordable and offer significant long-term value.
When choosing an entry door, homeowners have many options in either fiberglass or steel that will provide just the right features for most any home. Learn more about steel vs. fiberglass doors at www.provia.com/entry-door.
