When it’s time to choose the best vinyl replacement windows for your project, there are lots of things to consider -- the right look, comfort, energy-efficiency and long-term value are all factors that come into play. The Remodeling Magazine Cost vs Value Report for 2020 lists Vinyl Replacement Windows as one of the top five remodeling projects for return on investment, with an average of 74.7% of the cost of the project retained in resale. Now, more than ever, it pays to make a careful choice.
Here are three tips to help you make the best choice:
  1. Know your Zone: To help identify the most energy-efficient windows for a home, the federal EPA has developed a climate zone map, dividing the country into four regions. This map can be used to select windows with recommended values for two major characteristics that affect the energy efficiency of vinyl windows – U-Factor and Solar Heat Gain Coefficient (SHGC). The U-Factor measures the insulation value of the window; SHGC measures the amount of solar heat that passes through the glass.
  2. Check the Specs: Check the vinyl replacement window specs from manufacturers’ websites and compare those figures to suggested performance values for your climate zone. Make sure that the windows you choose have been independently tested to meet strict Energy Efficiency Standards, and check to see that the windows are ENERGY STAR Certified. Qualified, energy-efficient windows offer many benefits, including real money savings with lower energy bills.
  3. Get Technical: A wide range of glass upgrades can make windows more energy efficient, along with other components like spacers and weather stripping. Even the frame construction and frame material can vary from window to window. Well-made replacement windows can withstand the harsh effects of weather and ultraviolet light, maintain their dimensional stability and impact resistance, and keep their good looks for years.
When it comes to choosing the best vinyl replacement windows, a little diligence can really pay off. For more in-depth information on window styles, energy efficiency technologies and performance specs, visit the Windows Resources section of the ProVia website. To learn more about the windows remodelers ranked #1 in window quality, check out Remodeling Magazine’s annual Brand Use Report.
