Smarter Site Work with Geosynthetics
Use these versatile materials to reduce erosion, improve drainage, and boost the bearing capacity of the soil
11 MIN READ
Smarter Site Work with Geosynthetics, continued
Holes and ribs. Some geogrids are made by machinery that punches holes in a heavy sheet of polyethylene or polypropylene, then draws and stretches the material to create a framework of stiff ribs around openings 1 to 4 inches across. The stretching under controlled heat and pressure creates a strong plastic that can hold its shape under stress. Other companies use heavy plastic fibers to weave the grid pattern, and melt-bond or weave the intersections to create the screen structure.
But whatever the process, the products have similar engineering values. Their tensile strength and resistance to stretching give geogrids the ability to reinforce structural soils under roads, under foundations, and in earth walls. As with most geotech materials, the published values let the designer pick the material that’s right for the job; but most applications require a qualified engineer.
Geonets are like geogrids, but their crisscrossing strands overlap to form an open weave that allows drainage along the plane of the material. Geonets are strong enough to provide reinforcement the way geogrids do, but in practice they’re used almost entirely as sheet drainage materials, usually with filter-fabric facings to keep silt from clogging the weave. You won’t see them much in building construction — their biggest use is to line landfills and collect leachate — but they do turn up as drainage elements under rooftop gardens or concrete decks over occupied space.
Geocells
The U.S. Army Corps of Engineers developed the first “cellular confinement system” for gravel and soil in the 1970s as a way to build roads over soft ground (Figure 6). The grids of deep, tube-shaped cells keep loose material from spreading sideways, and spread vehicle loads over a wider area. In tests, heavy trucks made thousands of passes over a geocell roadbed with minimal rutting; without the system, the trucks quickly bogged down in the subgrade.
Figure 6.Cellular confinement systems, or geocells, lend great strength to roadbeds and embankments in heavy engineered applications. Gravel-filled Presto Geoweb geocell material provides a solid roadbed (top), while soil-filled Tenax Tenweb stabilizes a bank (center). Stacks of filled Terrafix Terraweb form a strong earth-retaining wall (bottom).
But roads aren’t the only use of geogrids. Stacks of geogrids can also make a strong earth-retaining wall, which can be seeded with plants on its face. And for light parking use, soil-filled cells provide protection for turf, so that cars won’t damage it (Figure 7).
Figure 7.Some geocell materials are designed for light-duty applications. This porous grass parking installation (GrassPave from Invisible Structures) provides a stable surface that can stand up to car traffic but avoids the need for storm drains by letting rain percolate into the ground.
Geocomposites
When you bond a layer of filter fabric to an open, free-draining component such as dimpled sheet plastic, drain tile, open-weave heavy geotextile, or geonet, you’ve got a geocomposite (Figure 8). These products provide a quick solution for site or foundation drainage and reduce the need for granular fill. Some products provide only drainage, while others can waterproof a foundation and provide drainage in one step. There are even specialized geocomposites designed for efficient venting of radon and other gases (Figure 9).
Figure 8.Geocomposite drainage systems, which combine a filter fabric with an open-weave web or dimpled sheet, provide high flow rates and quick installation. Some systems also provide waterproofing for foundations at the same time.
Figure 9.Besides fluid drainage, geocomposites can provide a vent for subsoil gases like radon, as in Colbond’s EnkaVent system. A dense mat of stiff nylon filaments bonded to a polyester filter fabric is placed on the prepared subgrade before the slab is poured; if radon is detected later, vent piping can be connected to the sub-slab air space to vent the gas to the outdoors.
But suppliers caution that if soils have heavy silt loading, the filters can become clogged. A soils engineer can provide appropriate details for specific site conditions; it’s a good idea in general to provide some coarse sand backfill in contact with the geotextile filter element (Figure 10). This combination of a sand filter and a fabric filter can be counted on for indefinite service.
Figure 10.Curtain drain systems can be more effective and quicker to build with geocomposite drainage components. Suppliers recommend a coarse sand backfill for filtration to prevent clogging of filter fabric. Flow rates can amount to hundreds of gallons a minute.
Resources
Suppliers
Amoco Fabrics and Fibers Co.
800/445-7732
http://www.geotextile.com
BBA Nonwovens-Reemay Inc.
800/284-2780
http://www.typargeotextiles.com
Belton Industries Inc.
800/225-4099
http://www.beltonindustries.com
Boom Environmental Products
800/770-2666
http://www.boomenviro.com
Carthage Mills
800/543-4430
http://www.carthagemills.com
Colbond Geosynthetics
The Netherlands
http://www.geosynthetics.colbond.com
Cosella-Drken
888/433-5824
http://www.deltams.com
Drainage Products Inc.
860/668-5108
http://www.drainaway.com
Eljen Corporation
800/444-1359
http://www.eljen.com/index.html
Evergreen Technologies Inc.
800/984-9784
http://www.etigeo.com
Geo-Synthetics Inc.
800/444-5523
http://www.geosynthetics.com
Greenfix America
760/348-7600
http://www.greenfix.com
Huesker Inc.
800/942-9418
http://www.huesker.com/usa
Invisible Structures, Inc.
800/233-1510
http://www.invisiblestructures.com
Lun-Drain
800/948-5603
http://www.lun-drain.com
North American Green
800/772-2040
http://www.nagreen.com
Presto Products Co.
800/548-3424
http://www.prestogeo.com
Profile Products LLC
800/207-6457
http://www.profileproducts.com
SI Geosolutions
800/621-0444
http://www.fixsoil.com
SolPlast, S.A.
Spain
http://www.solplast.com
(in Spanish)
Tenax Corp.
800/356-8495
http://www.tenax.net
Tensar Earth Technologies Inc.
800/836-7271
http://www.tensarcorp.com
Terrafix Geosynthetics Inc.
207/786-6808
http://www.terrafixgeo.com
WEBTEC Inc.
800/438-0027
http://www.webtecgeos.com
Western Excelsior Corp.
800/833-8573
http://www.westernexcelsior.com
For More Information
Geosynthetic Materials Association
800/225-4324
http://www.gmanow.com
Geosynthetic Research Institute
215/895-2343
http://www.drexel.edu/GRI
Geosynthetica
561/265-0472
http://www.geosynthetica.net
Industrial Fabrics Association International
800/225-4324
http://www.ifai.com
Ted Cushman
