A Shop-Built Conical Roof
Truss-style construction simplified the framing of this serpentine roofline
11 MIN READ
Site assembly. We loaded all the components onto a truck and hauled them to the site. On installation day, with a crane standing by, we cut back the existing roof overhangs and exposed the top plates where the new roof would connect. We set the steel I-beam with the crane, and a welder completed the moment frame. Meanwhile, the crew set and bolted the architrave beams on the columns. By late morning, we were ready to set the roof sections, beginning with the cone. We’d already outlined the MDO plate’s location on the underside of the truss chords, making it easy to accurately re-establish the overhangs on site. We secured the cone to the architrave with 3-inch Timberloks, screwing up through the plate into the bottom chords.
We installed the remaining roof modules in the same manner. By late afternoon, we had all the structural pieces set and bolted together. Last but not least, we hoisted the “bat” onto the cone, nailed it in place, and called it a day. Later, I went back with a reciprocating saw and notched the plate to install hurricane ties between the beam and each truss.
To complete the structure, the site crew filled in a few jack rafters between the truss assembly and the existing roof, then sheathed the underside with 3/4-inch plywood. This plywood, glued and nailed, serves as a tension diaphragm tying the bottom chords together to prevent the structure from spreading and settling. It was later covered with a beadboard ceiling.
Bending Crown
My usual approach to making curved crown molding is to strip-laminate rectangular section blanks around radiused forms and outsource the profiling to another shop. It’s costly, but the trim made that way is strong, accurate, and easy to install against vertical backing. On the job shown here, I had intended to save time and money by using Azek crown. A hasty bending test led me to think this would work, so I committed to making angled rafter tails on the trusses. Unfortunately, when it came time to actually install the crown, I realized that standard crown, when run around a radius, describes a greater diameter at its top than at its base. Either the top has to stretch or the base has to compress, but it isn’t something you can force even Azek to do. So I was forced to come up with a way to use a standard 4 1/2-inch wood crown. After some experimentation, here’s what we came up with.
I kerfed the crown at regular 2-inch intervals, using a razor saw to minimize stock removal and a simple miter-box jig to guide the cuts (A). We sliced the molding across its face, stopping the cut just shy of the top (B). The cuts were made at an angle to the face in order to allow the material to slip slightly past itself when bent. On such a large radius, only a small amount of movement is required of any single kerf.
A.
B.
C.
D.
E.
After striking the correct curves, we made bending forms on the floor (C). We worked slow-setting West System epoxy in with wood applicators, custom-made to fit in the tight kerfs (D). Hundreds of clamps and 60 man-hours later, we had our curved moldings. We reinforced the pieces on the back with fiberglass tape and epoxy resin. It took lots of hand-sanding and some West System 401 fairing compound to smooth out the surface, but under a coat of paint, the finished product looks surprisingly good (E). Necessity is truly the mother of invention.
All I had left to do was install the curved crown moldings, a detail that gave me an unexpected run for the money (see “Bending Crown”). Altogether, the work described here required 600 man-hours, or five weeks for a three-person crew.
Mike Rand runs a specialty millwork shop in Narragansett, R.I.
