Phase 1: Frames and Panels
1
of 12
The tapered center section of the newel is made up of four frame…
In some ways making the frames and panels, and assembling the four sides of the box newel post is the craftiest part of the project. Because the body of the box is tapered, you might be tempted to cut compound miters along the mating outer stiles of the panel frames. I devised a method to avoid making those tricky cuts. In the accompanying slide show you’ll see how I:
- Joined the frame members with pocket screws
- Rabbetted the frames to accept the panels with a router bit
- Cut the tapered panels on a table saw using a “sled” to maintain consistent angles
- Joined the panels to the frames
- Assembled the frame-and-panel sections
- Trimmed the mating panel rails with a flush-cutting router bit for perfect corners
