Building a Tapered Craftsman-Style Newel Post
Pocket-screwed frames attached to an inner plywood column made for efficient assembly
Phase 3: Fashioning the Bullnose Trim and Post Cap
I shaped bullnose trim to dress up the transition between the tapered section of the newel post and the straight top section; it also hides the joint. The post cap finishes off the top of the newel and conceals its hollow innards. In the accompanying slide show, you’ll see how I:
  • Shaped the bullnose profile with a hand-held router fitted with a beading bit
  • Beveled 5/4 poplar using a table saw to create stock from which the post cap would be made
  • Assembled four triangles cut from the beveled stock to fashion the post cap
  • Attached the post cap to the newel post
Gary Striegler
Gary Striegler, a JLC contributing editor, owns Striegler and Associates in Fayetteville, Ark., and teaches workshops at the Marc Adams School of Woodworking.
