Framing Rough Openings
A lesson in laying out and framing rough openings.
Retrofitting a Sliding Door
Adding an exterior door is more than just carpentry — plan on hiring an electrician, a plumber, and a drywall contractor
Retrofitting a New Door in a Brick Foundation
John Carroll explains how he modified an existing window opening to accommodate a new commercial-grade steel door.
Installing French Doors
Fix the leaks before they start with careful framing and the proper sill pan, flashing, and sealant.
Flashing an Entry Door
For doors with applied casings, simple flashings made from self-healing membrane serve the same purpose as fins
Securing Sidelights
I just replaced the insulating steel and fiberglass door in an entry door assembly with dual sidelights.
Securing Sidelights
