Self-Adhering Waterproofing Membrane
Tarco’s LeakBarrier BG700 modified bituminous membrane has a nominal thickness of 60 mils (1.5mm) with two layers of waterproofing: an SBS-modified bituminous layer and a high-strength, cross-laminated, high-density polyethylene film layer. The membrane is suitable for below-grade waterproofing applications and for use under siding, wall flashing, or exterior plaster, as long as it is protected from prolonged exposure to UV. According to the manufacturer, the self-adhering, self-sealing membrane adheres well to a variety of materials. tarcoroofing.com
