Using Lead Carpenters: Four Case Studies
"Sooner or later, a construction company owner is faced with an increasing number of jobs, and less time to manage them all. Many companies have found the solution in the lead carpenter system, where one carpenter takes full responsibility for each job, including material ordering, labor allocation, sub supervision, and client communication. In this excerpt from The Lead Carpenter Handbook, author Tim Faller uses four case studies to show how different companies have modified the system to meet their needs."
JUNE JLC 1999 Using Lead Carpenters by Tim Faller Sooner or later, a construction company owner is faced with an increasing number of jobs, and less time to manage them all. Many companies have found the solution in the lead carpenter system, where one carpenter takes full responsibility for each job, including material ordering, labor allocation, sub supervision, and client communication. In this excerpt from The Lead Carpenter Handbook, author Tim Faller uses four case studies to show how different companies have modified the system to meet their needs. Case Study One Hartman-Baldwin has a reputation for being a bit brainy. Located in a town with seven private colleges, many of the
Tim Faller
Tim Faller, known as the “Master of Production” at Remodelers Advantage, recently retired from his post as senior consultant where, for 17 years, he worked with hundreds of remodeling companies, large and small, to help improve profits by creating smooth, efficient production systems. Prior to his work with Remodelers Advantage, he worked in the field for 25 years as a production manager, project manager, and lead carpenter. He is the author of the The Lead Carpenter Handbook and Dear Remodeler.
