Shearwalls for Coastal Homes
To stay clear of engineering headaches, learn the new codes and design with the rules in mind
19 MIN READ
Shearwalls for Coastal Homes, continued
Case Study
My current project illustrates how I incorporate these structural solutions into my design concept from the outset (see “A House by the Water,” below). The main house is based on a traditional colonial rectangular shape but with several polygon bays. The bays gather in sunlight and air but are also stronger elements than flat faces that have to be reinforced.
For framing efficiency, I used full-length 40-foot wood I-joists for the first floor, running them from end to end of the house. They are supported on the two end walls and on three framed walls built on their own footings in the basement.
Two of the cross-basement walls also act as shearwalls, anchoring the first-floor diaphragm. Stacked directly above them is a pair of first-story shearwalls, which carry their share of the second floor’s live and dead loads and also serve to handle any lateral load carried into the house by the second-floor diaphragm. Above those two walls I set a third pair, which support the second-floor ceiling (the attic floor) and lock the floor and ceiling diaphragms for that story into the whole-house assembly.
Case Study: A House by the Water
The author designed this oceanfront home with code shearwall requirements uppermost in his mind from the concept stage. Working with an engineer, he stacked two primary first-story and second-story shear panels directly above basement-level shearwalls (section, below). In this way, he was able to accommodate most of the wind loads from the long axis of the house without cramping the generous space desired in ocean-facing rooms (floor plan, below). The unbroken expanse of the north-facing end wall also contributes (top photo). This wall was left windowless intentionally because it faces the neighboring house on the narrow lot. While the east-facing wall has many windows, the polygonal jogs provide lateral strength through geometry — the same way right-angle jogs in a long foundation wall do.
Proper shear panel nailing and hold-down placement are critical, so the engineer prepares a separate plan sheet and fastener schedule for this purpose. The schedule lists the hold-down spec and plywood nail size and spacing for each shear panel location (below).
Shear Panel & Hold-Down Schedule
All plywood panel locations (shown shaded above) are to be fastened to studs using 8d nails spaced at 6″ on-center at all plywood edges and at 12″ o.c. at all intermediate members except for the specially designated shear panel types indicated below.
Mark
Force
Height
Length
Shear
Hold-Down
Plywood Attachment
Hold-Down Connector
SP1
7680
20
384
3072
8d nails at 4″ o.c. at edges, 12″ o.c. intermediate
Simpson HD5A into (2) studs
SP2
12408
10
24
517
5170
Simpson HD8A into (2) studs
SP3
9040
16
565
5085
SP4
4032
576
5184
SP5
3552
395
3552
SP6
13760
20
688
6192
Glued with 8d nails at 4″ o.c. at edges, 12″ o.c. intermediate
SP7
8256
21
393
3538
SP8
6144
12
512
4096
Simpson HD6A into (2) studs
SP9
6885
13
530
4767
SP10
3090
515
4635
SP11
1650
275
2475
8d nails at 6″ o.c. at edges, 12″ o.c. intermediate
SP12
13760
24
573
4587
• All designated shear panels are to have solid blocking installed between studs along plywood edges.
• All Simpson hold-down connectors at the second-floor level are to be fastened through to the shear panel below.
• All Simpson hold-down connectors at the first-floor level are to be fastened into the foundation wall or supporting beam.
