Radiant Heating Workbook
Radiant Hydronic Heating Workbook
How well do you know radiant hydronic heating and cooling? Take the challenge by clicking on the image below. This isn’t a test of everything there is to know, but it will give you (or your manager) an idea of how well you know some of the key facts underlying skills. Answers are provided at the end. For any questions you get wrong, follow the links in the answers to hone your knowledge.
Radiant Hydronic Heating Challenge
Test your knowledge of radiant heating.
START NOW
Basic Instruction
Heat Transfer Through Buildings
An introduction to some building-science basics More
Piping Layouts for Hydronic Heat
The design of hydronic heat distribution piping affects overall comfort levels,... More
Hydronic Baseboard Basics
Finned-tube baseboard is the most commonly installed hot-water heating system in... More
Case Study: Hydronic Heat Retrofit
Using PEX tubing and panel radiators, the author retrofitted central heating with... More
Steam Heat vs. Hydronic Heat
A reader ponders whether to stick with steam or convert to hydronic. More
Hydronic Heating for Low-Load Houses
With the right hardware and layout, hot-water heating saves energy and makes ideal... More
Insulating a Radiant Slab
How much insulation is necessary under a typical basement radiant slab? More
Air-to-Water Heat Pumps Come of Age
Simple system designs reduce costs and improve efficiency More
Kelly and Dwyer ran the extensive tubing for the home's innovative radiant slab heating system themselves, as a cost savings and a learning opportunity. Main runs from the system's manifold were insulated. Here, Kelly works tubing into a bent conduit at the manifold connection.
Hydronic Heating
The full compilation of Hydronic Heating resources from JLC
Radiant Hydronic Heating Online References
Additional online references for building codes, training resources, industry information, and more
More From Our Sponsor
