The 28NR Joist Repair Notch Reinforcer from Metwood allows users to reinforce 5-inch-wide by 3-inch-deep notch cuts into 2×8 joists and does not require glue. It’s made from engineered light-gauge steel and can be used on engineered I-joists or conventional framing. By allowing larger openings in floor joists, the joist reinforcer simplifies the routing and installation of utilities. The reinforcers help restore the strength of floor joists weakened by the placement of large holes or cut-outs. metwood.com
Joist Repair Reinforcer
Met wood
