Expanding on the Redstick box level line, Milwaukee has added a new set of concrete levels. The levels are designed to be three tools in one: hand darby, screed, and spirit level. For lasting rigidity and to eliminate potential deformations, the levels are constructed of a magnesium core that is said to create a durable, protected setting for the vials. A plastic and rubber overmold provide added grip and make the levels easy to clean—just spray with water and wipe down with a cloth. Magnified bubbles are reportedly highly visible and are marked with four black band lines to delineate 1/8-inch and 1/4-inch pitch or 1% and 2% grade—useful for necessary water run-off applications. To help with grip and usability, the levels feature a keyhole shape, a precision-milled bottom, and a 2-inch-wide working surface with a rounded edge for smoothing and an angled edge for screeding or striking. Milwaukee is backing the levels with a limited lifetime warranty and limited accuracy warranty. The levels are available in three sizes: 24 inches ($100), 48 inches ($150), and 72 inches ($220)—sold separately, not in a kit. Carry bags will be available in 2019. —C.E.
