A.Henry Spies responds:Truss uplift is caused by differential
shrinkage between the upper and lower chords of a truss. In a
well-insulated house, the bottom chord is buried in ceiling
insulation. In the winter, that chord is kept much warmer, and
tends to dry to a lower moisture content than the top chord,
which is exposed to the ventilated attic air. This dry bottom
chord shrinks. Most of the shrinkage takes place across the
grain, but there is some lengthwise movement as
well.
In a triangular structure, such as a truss, if the bottom
member of the triangle is shortened while the two top chords
remain the same length, the peak of the triangle rises, pulling
up the bottom chord, which is attached by webbing or a king
post. As the ceiling rises, unsightly corner cracks may open
up. If the partition is firmly attached to the bottom chord,
the partition may even be lifted off the floor deck.
This is not a structural
problem, just a cosmetic
one.
In the summer, when the temperature and moisture content of
the top and bottom chords are nearly the same, the truss will
come back to its original position, closing any cracks that
have formed. In many instances, this cycle will occur only
once. In others it will occur on an annual basis.
How can you keep this from happening? You can’t fool
Mother Nature. A truss manufacturer can select chord members
that come from the outer parts of the tree, which helps. The
"juvenile wood" near the center of the tree moves more with
changes in moisture content than the mature wood. But the most
practical thing a builder can do is to use details which will
prevent the cracks from showing.
A connector such as the Stud
Claw (Stud Claw/USA, 5370
Chestnut Ridge Rd., Orchard Park, NY 14127; 716/662-7877) can
be used to connect the top plate of an interior partition to
the truss. A single nail that slides in a groove is tacked into
the bottom truss chord, allowing the truss to move vertically
with seasonal changes. The ceiling drywall should not be nailed
to the bottom chord of the truss within 16 inches of an
interior partition. Instead, it can be supported by corner
clips nailed to the wall studs, or nailed to a wider top plate,
as shown in the illustrations. This allows the drywall to flex
in the 16-inch space between the last nail in the chord and the
partition. The corner is held solid, so the tape does not
break. The deflection of the drywall is usually
unnoticeable.
— Henry Spies is a
building consultant formerly with the Small Homes
Council-Building Research Council of the University of
Illinois, and the Q&A columnist for
JLC.
