A.Mark Parlee, a general
contractor in Des Moines, Iowa, responds: In my
experience, water that gets trapped against fiber-cement siding
can be absorbed by the material, causing joints to swell and
shrink during freeze/thaw cycles.
On our jobs, we don't leave gaps for caulk at butt joints,
because I think that this detail contributes to the problem.
Instead, we snug the joints up tight and protect the seams with
a piece of metal flashing installed behind each joint (see
photos).
Caulk is usually used with fiber-cement siding to prevent
water intrusion at the butt joints (middle). An alternative
method, installing metal splines (top), also prevents water
intrusion and results in tighter, less noticeable joints
(bottom).
This metal spline laps over the siding course below, so any
water that penetrates the joint gets channeled out. The splines
wouldn't be hard to make on site, but our local lumberyard
stocks painted 6-inch-by-12-inch painted aluminum flashing
(white on one side, brown on the other) that's perfect for this
application.
We try to use factory edges with all our butt joints, though
sometimes they're a little rough. We've found that we can
tighten up these joints and make them less visible by scraping
away excess material on the back of the factory edge with a
utility knife.
When we do have to use a cut edge in the field, we make it a
point to prime the edge first to minimize water absorption.
Keep in mind that we're talking about fiber-cement siding here,
not cedar clapboards: It shrinks and swells, and so do the gaps
at the joints. But by eliminating the caulk and giving water a
quick route out, we can make the butt joints look pretty
good.
