Building Session: Realizing Success in Basement Remodels
Join JLC in this discussion on what to consider when turning below-grade spaces into comfortable, code-compliant rooms.
Turning dark, unused basements into bright, functional living space ranks as one of remodeling’s most rewarding challenges. Beneath the slab and behind the foundation walls lies an opportunity to transform neglected square footage into comfortable, code-compliant rooms that truly extend a home’s livability. But success below grade demands more than enthusiasm—it requires technical precision, thoughtful design, and a deep understanding of what homeowners need from the space.
In this Building Session, I discuss basement remodeling with two experts from DBS Remodel, a full-service design and remodeling firm based in Poughkeepsie, N.Y. Michelle Merck, remodeling consultant, and Mike Whalen, lead carpenter and frequent JLC contributor, each offer a practical look at how design, communication, and craftsmanship come together to make basement remodels work.
Together, we explore the core considerations every contractor should weigh before taking on a basement project:
  • How to frame the conversation with homeowners considering a remodel.
  • What to look for when assessing existing conditions, from moisture and drainage to red flags that can derail a job.
  • When egress and emergency escape openings (EEROs) are required—and how to integrate them seamlessly into the design.
  • How to plan for kitchens or bathrooms below grade, including plumbing, ventilation, and pump requirements.
  • Smart material selections that ensure long-term durability and client satisfaction.
Whether you’re tackling your first basement remodel or refining your approach to complex below-grade projects, this session offers proven strategies and field-tested insight from remodelers who have turned basements into inviting, livable extensions of the home.
This Building Session is underwritten by BILCO.
Clayton DeKorne
