Deck and Railing Skills Workbook
How well do you know decks and railings? Take the challenge by clicking on the image below. This isn’t a test of everything there is to know, but it will give you (or your manager) an idea of how well you know some of the key facts underlying skills. Answers are provided at the end. For any questions you get wrong, follow the links in the answers to hone your knowledge.
Deck and Railing Skills Challenge
Test your knowledge of decks and railings.
START NOW
Basic Instruction
Safe and Durable Decks
A casual inspection of just about any wooden boardwalk or ocean-side deck provides... More
Decay Resistance and the Code
Staving off rot with the appropriate design, construction and material selection More
Guards vs. Handrails
You should know the difference, because these two architectural components serve... More
Code-Compliant Guardrail Posts
Mike Guertin explains how to make fast, solid, and cost-effective connections by... More
Avoiding Deck Stair Defects
Build deck stairs according to best practices rather than code to protect your... More
Deck Foundations
When designing a pier or footing, consider load, soil conditions, and frost... More
Strategies for Safe, Affordable Decks
Deck code expert Glenn Mathewson explains how to build more efficiently and trim... More
Field Guide
Field Guide
Building outdoor decks can be a profitable business for builders and remodelers. But you have to get the details right to avoid failures from weak structural connections, weathering and corrosion.
Deck and Railing Skills Online References
Additional online references for building codes, training resources, industry information, and more
