Two New Ladders From Werner
The Dual Purpose and LeanSafe ladders solve some common set-up problems
Werner Co.
About a year and a half ago at STAFDA, Werner showed off a new ladder design, the 2-in-1 Dual Purpose Ladder; then in late summer 2017, it became commercially available. The Dual Purpose Ladder converts from a stepladder to an extension ladder thanks to a special hinge and clips that lock it in its respective position. Available in 6-foot, 7-foot, and 8-foot stepladder versions, they convert to 11-, 13-, and 15-foot extension ladders, respectively. Additional features include 3-inch-deep steps from bottom to top, oversized feet for added footing, and a padded V-rung when extended for working on things like wall corners, pole, or trees.
The Dual Purpose Ladder has a Type IA 300-lb. duty rating, is made of fiberglass, and is ANSI A14.2 and OSHA certified. Once extended, the top rung of the stepladder meets with the bottom rung of the extension ladder to create a 6-inch-deep platform. The Dual Purpose is not meant to be used as a double stepladder, on which you climb up on both sides. In its closed position, the Dual Purpose ladder is not designed to be leaned up against the wall to be used as a straight ladder.
OSHA regulations specifically state that because traditional stepladders are designed to be self-supporting, they should not be leaned directly against a vertical surface. Werner’s new Leansafe Ladder, however, is a newly designed stepladder that can be leaned against flat wall surfaces, wall corners, poles, and wall studs. The Leansafe has a Type 1A duty rating and a load capacity of up to 300 pounds. The Leansafe has large, non-marring rubber pads that Werner says maximize contact with the ground in both standard set-up and in leaning mode. The rear ladder rails lock in place when closed, and it features rubber bumper pads, a magnet for holding metal tools or bits, and holes on the top to secure various tools.
The Dual-Purpose ladder sells for $192 (6 foot), $219 (7 foot) and $254 (8 foot).
The LeanSafe is available in 4-, 6-, 8-, 10-, and 12-foot options. Prices range from $115 to $370.
The ladders are available through various online retailers, including Home Depot, as well as certain local distributors. Check Werner’s site for availability. Expect a 3-week lead time when ordering online.
This article originally appeared in Tools of the Trade.
Chris Ermides
