Does Threaded Rod Work for Anchor Bolts?
Q: When anchor bolts are out of stock at our local lumberyard, we frequently use lengths of threaded rod that we’ve cut and bent ourselves. A new foundation subcontractor recently said this is not permissible by code. Is he right?
A: Mac Hampson, a multi-trade building inspector in Wilmington, N.C., and author of “Behind the Walls,” responds: The foundation contractor is correct. Anchor bolts at the sill plate are not just “something to hold the wall down.” They are designed structural links in the load path that connect the wood framing to the foundation and help the building resist wind and uplift forces. Using plain, full-thread rods bent into an L- or J-shape as “anchor bolts” may feel like a practical field solution, but it often steps outside what the prescriptive residential requirements and the underlying structural design assumptions are based on.
For typical residential construction, prescriptive requirements and most engineered details assume anchors with known, established behavior. Typically, the design assumes:
–Recognized anchor bolts sized and spaced per the approved plans and applicable prescriptive tables (or as specified by the engineer of record);
–Conventional hooked or headed anchor configurations, or listed anchor systems, that have been tested for tension and shear;
–A continuous load path from roof to walls to sill/plates to foundation that is based on known anchor performance in concrete.
The key point is that the connection must be predictable, which is not the case with a site-bent full-thread rod. There is no verified hook geometry or bend radius tied to tested performance for that rod or bend configuration. There is no evaluation report or manufacturer data supporting “bent all-thread” as a cast-in anchorage method. As a result, the anchor performance assumed by prescriptive provisions or an engineer’s design may no longer match what is installed in the concrete.
Even before you get to the concrete, a threaded rod is not the same as a purpose-made anchor bolt: The effective steel area is reduced at the thread roots, and field bending adds variability.
On the concrete side, anchorage behavior and failure modes are addressed through ACI 318, an American Concrete Institute framework that’s referenced by the residential code for structural concrete where prescriptive provisions stop. That framework is built around standardized anchor types and tested assumptions—not improvised, site-bent rod details.
As with most structural details, if the anchor detail is not shown on the approved plans and is not a recognized prescriptive solution, the burden shifts to documentation. In practice, that means the installer should be able to provide either an Engineer of Record approval (a sealed detail or written acceptance tied to the specific condition), or a listed anchorage system with a supporting evaluation report and manufacturer installation requirements that match what is installed in the field.
If neither exists, the safest and most defensible path is to pause the work, document the condition, and involve the design professional or manufacturer before proceeding.
Mac Hampson
Mac Hampson is a North Carolina certified multi-trade building & fire inspector based in Wilmington, N.C.
