Wood Flooring
JLC Field Guide: Wood Flooring
The elegance of hardwood is unparalleled as a flooring choice. However, if it's not installed correctly, floor squeaks, shrinkage or buckling can ruin the job.
Learn More
Wood Flooring Featured Articles
Removing & Replacing Strip Flooring
Tips and tricks for blending new hardwood with an existing floor More
Hardwood Flooring over Radiant Heat
Hardwood floors can perform well over radiant heat, but it takes careful hvac... More
A Radical Approach to Protecting Finished Floors
Applying finish to the floor at the start of a job is unconventional, but it saves... More
Controlling Floor Vibration
A floor system that complies with the IRC's deflection limits can still feel... More
Installing Prefinished Strip Flooring
The prep work is the same as for unfinished strip flooring, but the installation... More
View All
Wood Flooring Instruction
Dimensional Changes in Wood
How to calculate the changes for whatever pieces you might choose. More
Fitting the Final Floor Board
Learn how to use a scribe block to get a perfect fit every time. More
Expansion Space for Wood Floors?
Many of the “rules” regarding wood flooring installation are based on mythology... More
Nailing Wood Flooring
Hammers, pneumatic nailers, and nailing machines all have their pros and cons. More
Finishing Laminate Floors
Installing hardwood over a concrete slab requires extra care and special materials... More
View All
